Default
Main
Main 2
Main 3
zero seconds
Close Session
Throttle
0.0 %
Brake
0 psi
FL
0.0
kPa
FR
0.0
kPa
RL
0.0
kPa
RR
0.0
kPa
ECT
0 °F
IAT
0 °F
MAF
0.00 lb/min
MAP
0.0 psi
Fuel Level
0
Oil Pressure
0 psi
Voltage
0 V
Speed
0 mph
160
0
RPM
0 rpm
7000
0
Throttle
0.0 %
100
0
Brake
0 psi
800
0
Retard
0.0 °
15
0
Spark Adv
0.0 °
35
0
EQ Ratio
0.00 λ
2
0
MAP
0.0 psi
15
0
ECT
0 °F
240
60
160
0
80
7000
0
3500
SPEED
0 mph
Speed
mph
RPM
0 rpm
RPM
rpm
100
0
50
800
0
400
THROTTLE
0.0 %
Throttle
BRAKE
0 psi
Brake
psi
15
0
7.5
35
0
17.5
2
0
1
RETARD
0.0 °
Retard
SPARK ADV
0.0 °
Spark Adv
EQ RATIO
0.00 λ
EQ Ratio
λ
15
0
7.5
240
60
90
MAP
0.0 psi
MAP
psi
ECT
0 °F
ECT
°F
GEAR
0
0
rpm
0
RPM
mph
0
SPEED
Waiting for GPS data
1x
Loading interface
00:00:00 / 00:00:00
